Activity Forums Apple Final Cut Pro Legacy Updating nested sequences
  • Updating nested sequences
    Posted by Christopher Pavsek on July 14, 2005 at 8:21 pm
    I’m having trouble getting sequences to update in FCP 4.5.
    Is there a particular protocol to follow to make sure that a changed nested sequence gets updated automatically in a project?
    David Bogie replied 21 years, 1 month ago 3 Members · 2 Replies
  • Todd Beabout
    July 14, 2005 at 8:46 pm
    If it has been rendered it usually won’t update. Right click the nest to open in viewer and then change a setting forcing a re-render (like opactiy, scale, etc.), then change it back to original setting. This is my work-around, there may be more/better ones.
    -Todd Beabout
    Vazda Studios
  • David Bogie
    July 14, 2005 at 8:53 pm
    It also depends on where the nest originated. As silly as it sounds, the 4.5 manual contains a good explanation of how to create and use nests. Not all of us do it properly.
    bogiesan
