Activity Forums Apple Final Cut Pro Legacy Updating Everything-Question About Order
  • Updating Everything-Question About Order
    Posted by John Fishback on December 3, 2005 at 5:18 pm
    I’m finally updating to Tiger and FCP Studio 5. I’ll be doing an Erase and Install on a 2nd internal drive as recommended by many on the Cow. My question relates to the firmware/ROM updates for ATTO, ATI, AJA and Huge. Should these be done before or after the OS install? Also, what are your thoughts about using the Transfer Information function during the install.
    I’d like the option of using FCP4.5 and OS 10.3.8 on my other internal drive as a backup in case I have issues with the new installation. Will the firmware updates cause any problems with the IO, etc. using the older system?
    John
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Dual Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
    John Fishback replied 20 years, 8 months ago 2 Members · 3 Replies
  • Walter Biscardi
    December 3, 2005 at 7:19 pm
    Install OS
    Run Software Update to update everything
    Install your new FCP Software
    Run Software Update again to update everything in FCP
    Launch FCP to ensure it launches correctly. Quit.
    Go to all the websites of your hardware and update.
    That’s the order I go in, though you could do all the hardware updates after the OS Install / Software update.
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • John Fishback
    December 3, 2005 at 7:40 pm
    Thanks, Walter. As usual, you’re a great help.
    John
    FCP4.5 DVDSP 3.0.2
  • John Fishback
    December 4, 2005 at 2:24 pm
    Okay, I’ve just installed Tiger on a second internal drive leaving OS 10.3.8 on the other. I’ve done a couple of rounds of system updates to bring Tiger current. TIger is the startup drive. I have two questions. Once they’re resolved, I’ll install new device drivers, firmware and FCP Studio 5.
    I would like to migrate user data from the old system to the new (email & intenet accounts, address book, etc.). When I use the Migration Assistant it shows 7Gb of data to be migrated. This seem like a lot. Is there any way to know exactly what is being moved before doing it? I don’t want preferences, etc. that might interfere with the new FCP Studio 5 apps.
    When I try to look at the drive that has OS 10.3.8 on it, the finder hangs up with the spinning wheel of death. Is this because Tiger doesn’t like looking at another system disk or is something messsed up?
    John
    FCP4.5 DVDSP 3.0.2
