Activity › Forums › Adobe Premiere Pro › Updating CS 5.5 issues
Posted by Chris Tompkins on October 7, 2011 at 9:46 pmMac 10.6.4
Run the update from the help menu.
It starts, it downloads and then hangs with this:But, I can’t find and Dynamiclinkmanager to close – such b.s.
I have work I need to finish.
Anybody have a solution?Chris Tompkins
Video Atlanta LLCRalph Mccarron replied 14 years ago 5 Members · 11 Replies -
Ben G unguren
October 7, 2011 at 11:09 pmJust got the same message today when upgrading! Open your Activity Monitor (in your Utilities folder) and find “dynamiclinkmanager” in the list of processes. Select it, and press the stop sign. When prompted, choose the “Force Quit” option.
I think the dynamiclinkmanager turns on whenever you start to run PPro or AE, etc — so it can keep track of when files are updated in their respective apps. A super-handy thing to have, but yes: a pain to shut off.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Todd Kopriva
October 8, 2011 at 3:48 pmYou can also just restart your computer to stop all such processes. I tend to do my updates by choosing Help > Updates in Bridge.
The Dynamic Link manager process is essentially what it sounds like: It manages the passing of information back and forth between After Effects and Premiere Pro when you use Dynamic Link. It’s supposed to stop when the other (host) applications stop, but sometimes it stays open even when the host applciations are closed. That’s a bug.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Chris Tompkins
October 8, 2011 at 5:25 pmThanks Ben, That worked. I really appreciate it.
I had re-booted, then back into the update process and it would hang there again. Did this a couple of times. I could not get around it.
Got it now.
Chris Tompkins
Video Atlanta LLC -
Chris Tompkins
October 8, 2011 at 5:41 pm -
Ben G unguren
October 8, 2011 at 9:28 pmAre you getting that error after a full computer restart as well?
Ben Unguren
Chris Tompkins
October 8, 2011 at 9:37 pmYes.
Did a reboot.
Launched app, select update.
Does it’s thing for awhile.
Then error.Chris Tompkins
Video Atlanta LLC -
Robert D’alexis
October 9, 2011 at 12:07 amTry killing/ending the dynamiclink process and then get on with the updating process without rebooting.
Chris Tompkins
October 9, 2011 at 1:09 pmThanks,
This is what I did.
Fresh Reboot.
Run Update.
Hangs dynamiclink.
Force Quit.
Finishes download/update.
Error, did not update.Chris Tompkins
Video Atlanta LLC -
Todd Kopriva
October 10, 2011 at 4:12 pmThe error message that you showed doesn’t say that Premiere Pro CS5.5 is failing to update. It says that the updates for the previous (5.0) version of Adobe Media Encoder is failing to update. Furthermore, it’s saying that the failure is because of the incorrect moving or deletion of AME CS5.0… as if you deleted or moved the AME CS5.0 application without using the uninstaller.
Chris Tompkins
October 10, 2011 at 4:56 pmThanks Todd, I missed that.
I had that original error when using the trial of CS5.5 and that threw me off, so I did a delete on all things adobe b/4 installing the purchased version of CS5.5
Great to see you folks on the boards helping out.
Chris Tompkins
Video Atlanta LLC
