Activity Forums Adobe Encore DVD Updating a project with new files
  • Updating a project with new files
    Posted by David Strelitz on November 29, 2006 at 12:29 pm
    In Encore 2: I have a project that has 16 PSD’s as menus and 15 video clips imported as m2v and wav. This project is now undergoing being reworked.
    Is there a way, perhaps by removing some of the files in the sources folder to force the new files to be seen and updated. I realise that the timelines that are shorter are going to need to be re-imported but the PSD’s just dont get updated without deleting and removing
    David
    Joe Bowden replied 19 years, 9 months ago 2 Members · 5 Replies
  • Joe Bowden
    November 29, 2006 at 3:43 pm
    Encore 2.0 provides the way to solve both problems: replace menu and replace asset.
  • David Strelitz
    November 29, 2006 at 6:11 pm
    Joe, these options are greyed out on PSD’s and you cannot replace a m2v asset with one of the same name. Am I missing something?
  • Joe Bowden
    November 29, 2006 at 6:54 pm
    You should be able to replace a menu without issue. Open the menu you want to replace, then choose Menu > Replace Menu.
    Rename your new M2V files and you can use them to replace the existing M2V files in the project.
  • David Strelitz
    November 29, 2006 at 10:30 pm
    Thanks for the advice on this – I had to do the psd’s manually as the buttons had been added from within Encore to the supplied artwork backgrounds(which had no buttons) as such Encore would not replace the files. Job done…eventually.
  • Joe Bowden
    November 29, 2006 at 10:52 pm
    Glad to hear you got it done. In future, if it is just a background, you can have import it into Encore’s Library, and then replace the background.
