Activity Forums Adobe Premiere Pro updates for hd
  • updates for hd
    Posted by Derek Negron on August 4, 2008 at 10:22 pm
    Hello-
    I currently have an alenware pc-a51 aurora. I want to start editing hd using adobe premier pro. What is the ideal processors and memory for this? Also what capture and edit cards can you recommed?
    Derek
    Jeff Brown replied 18 years ago 3 Members · 2 Replies
  • Steven L. gotz
    August 5, 2008 at 8:29 pm
    The requirements are as follows:
    https://www.adobe.com/products/premiere/systemreqs/
    I recommend the fastest PC with the most cores that you can afford.
    You will want at least 1GB for each core. You probably can’t buy Windows XP anymore, but if not, CS4 will probably support Vista 64. So plan ahead.
    You should only need firewire, no special capture or edit card.
    Steven
    https://www.stevengotz.com
  • Jeff Brown
    August 6, 2008 at 2:48 pm
    Caveat: if you want to edit non-HDV HD, that is, less-compressed HD, you will need a higher-end capture/output card, and a large disc array (RAID). You might now be able to edit MXF files without the above, but I’m not sure. Too many damn formats these days. The nice thing about digital standards: there are so many to choose from.
    -jeff
