Activity Forums Adobe Premiere Pro Updated Premiere Pro CC 2015.3 – Audio Missing when Import
  • Updated Premiere Pro CC 2015.3 – Audio Missing when Import
    Posted by Eva Zahar on July 22, 2016 at 11:40 am
    Hey guys,
    So I finally updated my Premiere Pro and now starting on a new edit. When I import the clips, some come with audio but most don’t; they become only video clips without any audio attached to them. May I know why this is and how do I fix it? I only have until next Friday to complete a half-hour documentary so I would really, really, really appreciate it if someone could help me out asap. Really hope to hear from anyone of you soon, take care and “help”.
    Robert Stone replied 9 years, 11 months ago 8 Members · 13 Replies
  • 13 Replies
  • Jon Doughtie
    July 22, 2016 at 6:58 pm
    Eva, we need more information about exact version of the software, the system you are running, and the file types/codecs you are dealing with. Please share that information.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Tero Ahlfors
    July 22, 2016 at 7:24 pm
    Have you waited for the audio to conform?
  • Kevin Monahan
    July 22, 2016 at 9:13 pm
    Hi Eva,
    Delete media cache, rename or move your media folder, relaunch Premiere Pro, then reconnect media, if necessary. This should get you back to square one.
    If I knew a bit more about your case, I could help you prevent this issue in the future. Typically, you have this problem if you update your software in the middle of a project, something that is not recommended. If that was your issue, try to finish projects before updating.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Eva Zahar
    July 26, 2016 at 6:42 am
    Hey Jon,
    Thank you for getting back to me so quickly and my apologies for the late reply but here are the details of my computer :
    Intel Core i7-6700k CPU @ 4.00GHz
    16GB RAM (Corsair)
    Asus Z170 motherboard
    Asus Geforce GTX 750Ti graphics card
    C Drive 500GB SSD
    With 1TB render drive and 3TB work drive
    Windows 10
    The footage used are :
    Panasonic 50fps Bit rate 384kbps (6 channels)
    GoPro 29fps Bit rate 125kbps (2 channels)
    Canon 5D 29fps Bit rate 1542kbps (2 channels)
    I can’t get hold of the filmmakers for now; still on their European summer holiday so I am not sure which Panasonic and GoPro cameras they used. So I hope this helps and again, my apologies and thanks again.
  • Eva Zahar
    July 26, 2016 at 6:44 am
    Hey Tero,
    Yeah, I did. But when imported, they just came in that way; without any audio. Even after changing my cache to someplace else, still the same result. So I am a bit perplexed because this has never happened to me using any version of Premiere before. I am curious to know what the problem really is.
  • Eva Zahar
    July 26, 2016 at 6:52 am
    Hey Kevin,
    Thanks so much for your prompt reply and my apologies for taking so long to get back to you but yeah, that’s the first thing I did when it happened but still no difference. I deleted my cache files, changed my cache to a whole new folder and started the importing process again, but still not luck. They still come in without any audio. Some Canon and Panasonic footage are fine; imported as per normal with both video and audio but most of the GoPro footage are imported without any audio, video only. Unfortunately, 80% of this project were shot on GoPro so I really need this to work. I am still quite excited to use the new Premiere Pro so I would really appreciate the help. But first, here are the details of my computer :
    16GB RAM (Corsair)
    C Drive 500GB SSD
    Windows 10
    Software Version :
    Premiere Pro 2015.3
    I can’t get hold of the filmmakers for now; still on their European summer holiday so I am not sure which Panasonic and GoPro cameras they used. But I hope this helps and again, my apologies and really hope to hear from you soon.
  • Eva Zahar
    July 26, 2016 at 6:53 am
    Oops, sorry I missed out one more information; the software I am using is Premiere Pro 2015.3. Thanks so much and I hope to hear from you soon.
  • Joshua Jackson
    July 29, 2016 at 3:03 pm
    I’m having a very similar problem.
    I shot some footage with 3 smartphones and a point-and-shoot camera.
    They are all MP4 files.
    They play in various players and import into Sony Vegas without issue.
    I have Encore CS6, so I figured I would give Premiere Pro CS6 a try.
    Interestingly enough, the audio is just fine in PP CS6.
    Any ideas?
    JJ
  • Jeremy Rowell
    August 1, 2016 at 6:52 pm
    Having the same issue. Came in this morning and it looks like my adobe suite was updated while I was on Vaca. Everything I import has no audio. Only the video is able to be imported. tried clearing cache. anyone find a solution?
  • Jeremy Rowell
    August 1, 2016 at 7:14 pm
    trying to find work arounds. If I export from media encoder as AAC audio it imports, but mpeg and dolby audio do not import. In fact if I export from media encoder one of those formats, the file audio will not play on my system. any suggestions?
