Activity › Forums › Zaxwerks › Updated invig pro 5.0.8 but renders crash constantly
  • Updated invig pro 5.0.8 but renders crash constantly
    Posted by Matthew Lennium on October 26, 2011 at 10:43 am
    Updated the new 5.0.8 invig pro just recently and now I can’t render anything, Previous versions have always been crashy but have learned to be gentle with them and not do things that cause crashes but never had it so I couldn’t render the finale product. Went back to 5.0.6 and works fine!, as long as you don’t double click things or change a color or text after you’ve animated it.
    I have read other post where they couldn’t render as well. This program has always been very unstable across 3 different computers, now using something very powerful, with 16g ram and I still get crashes. I had always thought my computer was not up to speed but really I shouldn’t have to go above what I am using now.
    Edward Wu replied 14 years, 11 months ago 3 Members · 4 Replies
  • Fernando Mol
    October 26, 2011 at 1:55 pm
    I have found myself having crashes sometimes, but problem was solved managing the memory settings in After Effects.
    In my opinion, if you’re working in HD having 16G of RAM is not that powerful, so you want to be sure they’re well used.
  • Edward Wu
    October 26, 2011 at 4:32 pm
    Hi Matthew,
    Sorry to hear about the rendering issue you’re running into. Are you not able to render out any projects or just the one you’re currently working with?
    Like Fernando suggested, we can try adjusting some of the settings and see if that helps with your render. In the Invigorator Output panel, be sure you are using the Invigorator Renderer instead of the OpenGL Renderer. Also, go into the Invigorator Preferences, and try disabling the setting “Multithreaded Rendering”. Then, go into the After Effects Preferences and turn off the Multiprocessing setting. See if changing these settings helps with your rendering.
    If you are on a Mac, please send the crash report to me at ed@zaxwerks.com. We can take a look at the crash log to determine what is causing the crash on your system.
    Best,
    Edward
  • Matthew Lennium
    October 29, 2011 at 8:36 am
    Seems this render issue I was having is due to me trying to render previous things made as I am able to render new content fully without changing any settings in 5.0.8. So I am glad that I can use the product but sad that I have lost everything I had been working on 🙁
  • Edward Wu
    October 31, 2011 at 11:16 pm
    Hi Matthew,
    Try saving the Invigorator scene. Then, delete the Invigorator layer from your project, and re-apply it again. Then load the scene and see if this helps.
    If you’re still having issues, try sending the project file to me at ed@zaxwerks.com and I’ll take a look.
    Best,
    Edward
