Activity Forums Adobe Premiere Pro Update without removing previous versions PP CC2017?
  • Update without removing previous versions PP CC2017?
    Posted by Walter Stabb on September 19, 2017 at 9:01 am
    Hi all,
    Quick question. Previously when updating Premiere Pro app there was the possibility, through the advanced menu of the update window, to untick the default remove previous versions. Is a similar function available in the current version of CC (which doesn’t seem to feature an Update window)?
    I am aware of the process to install previous versions, which clearly provides a work around but would rather just install new versions parallel to the previous.
    Walter Stabb replied 9 years ago 1 Member · 0 Replies
  • 0 Replies
