Activity Forums Adobe After Effects Expressions Update “statictext” on UI
  • Update “statictext” on UI
    Posted by Loris Grifa on February 19, 2018 at 12:57 pm
    Hi to everybody,
    here i got an extracted from my code.
    Is it possible to update the value of my “statictext” that refers to a function that simply checks a number of remaining object?
    In the same interface there are a couple of buttons that modifies that number, but the value is calculated only when the UI is built,
    Thank’s a lot
    var group_one = MyWin.add("group", undefined,"G1");
    group_one.orientation = "row";
    group_one.add("statictext", undefined, "TOTAL ITEMS");
    group_one.add("statictext", undefined, ReadElemNum());
    Loris Grifa replied 8 years, 7 months ago 2 Members · 3 Replies
  • Loris Grifa
    February 20, 2018 at 4:50 pm
    No one can help?
  • James Ronan
    February 21, 2018 at 2:56 pm
    I’m not entirely sure what your trying to do… But here is an example of static text changing values when a slider is moved.
    var w = new Window ("dialog", "test",undefined,{}); // create window
    var slider = w.add("Slider",undefined); // create slider
    slider.value = 50; // set intital value as 50
    var staticText = w.add("StaticText",undefined,"50"); //Create static text
    slider.onChanging = function() { //create onchanging event for the slider that updates the staticText everytime there is a change
    var percentage = slider.value;
    staticText.text = percentage.toString();
    w.show(); // show window
  • Loris Grifa
    February 22, 2018 at 9:21 am
    Great!
    the code u posted was really helpfull to understand the logic!
    Now, my index, is shown perfectly!
    Thank’s again
