Activity Forums Adobe Encore DVD Update problem for 1.5.1
  • Update problem for 1.5.1
    Posted by Chris Lieber on June 7, 2005 at 6:22 am
    I am trying to install the 1.5.1 update but the install is not working. It says to specify the folder and I am but the error is that it needs to be where the Encore program is installed. There are no folders per se, but the exe file is in the directory I am specifying.
    Any thoughts on this?
    The computer says to reinstall from the disc which I have done to no avail.
    I gotta get this DVD out as I am under a few film fest deadlines.
    thanks
    Chris
    Chris Lieber replied 21 years, 2 months ago 3 Members · 4 Replies
  • R. Hewitt
    June 7, 2005 at 11:21 am
    Just a thought, the folder isn’t set as read only is it?
    Did you change the default install directory when you first installed the full app?
  • Joe Bowden
    June 7, 2005 at 1:48 pm
    It could very well be that you already have Encore 1.5.1 installed.
    When you go to Help > About Adobe Encore DVD, what is the build number listed at the bottom of the screen?
    -Joe
  • Chris Lieber
    June 7, 2005 at 2:33 pm
    Maybe I do have it….it says DVD Encore 1.5 Build 1.5.1.42735
    But if that is the case and I actually was able to animate the menu, the bigger picture is that the program will not burn my DVD. I posted some other posts regarding the error and what I have been doing to try and get to burn.
    something tells me i need to try the simplest thing and try and burn that. Also does the transcoding have anything to do with potential errors or the type of DVD Burner? I have the Sony Burner that burns +R and -R.
    Just some more thoughts.
    thanks.
    Chris
  • Chris Lieber
    June 7, 2005 at 2:40 pm
    I just tried to set up the most basic DVD. I inported the transcoded footage, grabbed a menu and set the link to the default play. I checked for errors, then tried to build, but i get that abnormal error deal. I think something bigger is at work here.
    Any thoughts?
    Thanks.
    Chris
