Activity Forums Adobe After Effects Expressions Update multiple expressions using one master expression? Or a text layer that contains the expression text?
  • Update multiple expressions using one master expression? Or a text layer that contains the expression text?
    Posted by Robert Headrick on May 1, 2014 at 3:16 pm
    Hope I can phrase this in a way that makes sense. I’m using one of Dan Ebbert’s overshoot expressions to add a subtle overshoot/swing to text layers that are rotating into place. I have lots and lots of text layers, and I want them all to have the same motion. However, if I were to decide later that I want more or less overshoot, or wanted to tweak the motion in any way, I would have to manually copy and paste the updated expression into the rotation property for each individual layer… lots of manual work.
    Is there a way to tell a property to use an expression that’s located elsewhere as its own expression? For example, what I tried and failed to do was to write the expression in a text layer, and then use the Source Text property of that text layer as the expression on my rotation. That doesn’t work, but something tells me maybe there’s a way to do something similar? I just want to be able to update a single instance of my expression and have all the other instances mimic it without having to manually replace them. Make sense at all?
    Chris Gosling replied 12 years, 2 months ago 4 Members · 4 Replies
  • Dan Ebberts
    May 1, 2014 at 5:46 pm
    You can execute an expression saved in the source text of a text layer, like this:
    eval(thisComp.layer(“expression text”).text.sourceText.value)
    However, it’s not particularly efficient. As an alternative, I would look at tying the expression’s parameters (frequency, amplitude, etc.) to master controls on a control null.
    Dan
  • George Goodman
    May 1, 2014 at 6:23 pm
    That’s a feature request I’ve submitted a few times. You should do the same:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    “|_ (°_0) _|”
    Sincerely,
    George
    http://www.vimeo.com/georgegoodman
    http://www.linkedin.com/in/georgefranklingoodman
  • Robert Headrick
    May 1, 2014 at 6:24 pm
    Thanks Dan! Your first point is exactly what I was looking for, and your second point is even better. 🙂
  • Chris Gosling
    May 27, 2014 at 11:57 am
    Had the same problem and I ended up buying pt_ExpressEdit 2 from the aescripts.com website. Makes the process of dealing with multiple expression layers easy.
    I am not the developer, just a big fan.
    Chris
