Activity Forums AJA Video Systems Update – Conflict with AJA/Fusion 500P/TEMPO X4P
  • Update – Conflict with AJA/Fusion 500P/TEMPO X4P
    Posted by David Telling on November 15, 2006 at 11:49 pm
    Thanks to everyone who’s tried to assist me with my “disappearing drives and Final Cut Freezing Problems.”
    Unfortunately, after continuing to troubleshoot as best I can, I’m still having most of the same problems that have essentially closed my shop for a while!
    Update:
    I bought a second Tempo X4P card which I had shipped overnight for Saturday delivery – Unlike the first card, it was “plug and play” and “cured” the mounting at start up problem I had.
    Unfortunately, Final Cut problems continued with the 5 x 500 RAID enclosure connected to the computer. The intermittent freezing also extended to tests playing back files in QuickTime Player, too.
    I bought new replacement eSata cables – same results
    I replaced Power Cords – same results
    I tried connecting the Media Drive Enclosure to a second G5 Dual 2.0 with a new install of Final Cut Pro (then updated it to 5.04 and QT Pro 7.1.3 so it matched the other computer). EVEN on a different computer I had the exact same issues (which hopefully took logic board, RAM, and a problematic Final Cut out of the equation.)
    And yes, after all of this, I did put the 5 x 500 Media RAID drives in the other enclosure to test that – Unfortunately…SAME PROBLEMS!
    HOWEVER… when I attached my second Fusion 500P (with the 2 x 500gb drives striped as a fast back up for the 5×500 RAID enclosure), and tried working with the backed up versions of those same projects/files I could not get Final Cut to freeze.
    Thinking I might have at least one trustworthy set up, I decided I would make a “back up of my back up” – going from this 2 drive BU RAID to one of the other 3 individual 500gb drives I have in the same 500P enclosure. Then I would break up my 5 x 500 Media Raid, test the drives individually and go from there.
    However, trying to the full set of backed up files from the 2 x 500 RAID to one of the individual 500Gb drives in the same enclosure – I got the gray screen of doom, requiring a power down. This happened 3 separate times to that drive (all at different stages of transfer). I then had the same problem trying to copy to the other 2 drives in the same enclosure!!!
    I thought it might be a corrupt media issue. So by comparing the file sizes of the original BU files to files that were copied, I managed to track down the individual files that were being copied each time the death screen appeared. It was never the same file! AND – although trying to play those parially coped files would display error boxes as expected – when I went back and played the original files, they opened and played just fine!!!!…AND I had no problem at all copying those same filesINDIVIDUALLY from drive to drive!
    So all of this made me lose faith in the integrity of the second set up, too.
    The problem is I have 3 irreplaceable projects sitting A) as work files on the first Fusion 500P and B) backed up on the second FUSION 500P. Worrying about the integrity of the back up set up is obviously a big concern if I have to erase, test and reformat the work drives!!!
    So: Two Tempo X4P Cards, 4 enclosures, 2 G5s (and as many different configurations as I could muster) later – I’m still unable to use the drives for work, and I’m worried sick that even though media files do seem to play and projects do open – there may be some kind of corruption that will make transferring and retrieving fully workable projects an impossibility!
    Sorry to wear out my welcome with all of this stuff, but this has become a real “head in hands and sob” kind of dilemma that I actually bought the equipment to try and avoid! I’m getting so far behind, and it is really getting tough to explain the delays to my clients.
    I will be getting feedback soon from an engineer at Sonnet who asked for my system logs which I have sent down on Friday.
    As always, feedback is more than welcome. Thanks.
    David Smith replied 19 years, 9 months ago 3 Members · 4 Replies
  • David Telling
    November 16, 2006 at 12:21 am
    Please could I get some help deciphering this email and it’s practical application to what I have been experiencing…
    This is the email the Engineer at Sonnet (who looked over my System Logs sent) to their tech support phone people (who couldn’t really tell me what it meant).
    “Ouch. The most obvious thing is the high number of errors on channel 0 – I don’t see any errors on Channel 2 at all (which is where he apparently has his second enclosure). He’s probably not going to like it, but can we detach the fusion 500 from port 0 – I don’t know why it would be problematic, but it just seems odd that all the errors are happening on that line – and a lot of errors it is. Almost every time the machines restarts, there are significant numbers of errors on channel 0.”
    For clarification:
    When he speaks of “errors” – where are these coming from?
    Does this consequently translate to corrupt files being saved/stored on the drives?
    Would these “errors” be transferred in the process of backing up from drive to drive?
    I know I’m able to play back media files, and projects – but are these errors “in” those files and have therefore permanently screwed them up?
    Am I in deep trouble here?
    What should be my next step having received this feedback.
    Thanks for helping to clear this up.
  • Bob Zelin
    November 16, 2006 at 2:19 am
    David –
    this is not a SATA forum, nor is it a Sonnet Forum. I thank AJA and Creative Cow for not objecting to all this “OT” that does not relate to AJA products on their forum.
    This is my opinion. You actually answered your own questions here when you said –
    “And yes, after all of this, I did put the 5 x 500 Media RAID drives in the other enclosure to test that – Unfortunately…SAME PROBLEMS! ”
    REPLY – you are in the middle of a big, important project, and you can’t reformat your drives, and you are crashing no matter what you do. I use SATA like this all day long without these problems. You have followed the correct steps – you have a 2nd computer, you have a second X4P card, you have a second Sonnet 500P chassis – AND IT IS STILL FAILING. You feel that this whole SATA thing is flakey.
    But you have NOT REFORMATED – I can only ASSUME that there is something wrong with your media, and I don’t know what it is. In my OPINION, if you were to stick different drives in your system (or dedicate two drives for this test), and digitize NEW MATERIAL (not copy old media) onto these new drives, you would have NO PROBLEMS. This is easy for me to say, as I am not in the middle of a big paying job, that pays your bills – but this is how you will identify your issues. I was about to write “if I am wrong about this, you will need to do a ground zero reinstall of your OS, and FCP and try again” – but I am wrong, and you do not have to do this, as you have a SECOND MAC there, which serves the same purpose. I can ONLY ASSUME that there is something wrong with your media – and even though you transfer this material to other drives, and take the drives and put it into a second chassis, with a second X4P card, and a second eSATA cable, in a second computer, AND STILL HAVE PROBLEMS – it’s got to be your media.
    The only other assumption anyone could have is that this entire Sonnet SATA think is a piece of flakey crap, and I can assure you that this is not the case (as many others on this list can confirm). In my opinion, you should not proceed any further without dedicating a couple of drives to REDIGITIZING media, to see if it works, or locks up. I don’t know what you have on the drive array with 2 drives striped RAID 0, and the 3 that are single drives, but if you can, I would reinit this array to RAID 0 all 5 drives, and REDIG YOUR MATERIAL (easier said than done) – and you will see that nothing locks up or crashes.
    I RESOLVED THIS SIMILAR PROBLEM ON AN AVID THE OTHER DAY. AVID Meridian System MAC OS-X 10.2.6. System would not boot up – 4 Seagate SCSI 73 Gig drives. We play with the cables, and eventually get the system to boot. We can play material back from the drives, but we can’t write to them. They try to transfer the media off these drives, and the system crashes. As they continue to use the system, it keeps crashing, and the drives keep hanging up. I finally convince them to reinit the drives, where we split the RAID 0 of 4 drives into 2 groups of 2. I figure that one of the 2 groups will fail, and then I will identify which one is the bad drive. Once we reinit the drives, and they redigitize their media, THERE ARE NO MORE PROBLEMS ! No drives have failed for 4 days now. I don’t understand why corrupt media can make a drive fail, so that it even stops the system from booting up some times, but it did.
    Pick 2 drives, take ALL OTHER DRIVES off system, redig, see how stable it is. I bet you have no problems.
    I feel your pain.
    If you wish to take this further, please email me off this forum at maxavid@cfl.rr.com.
    Bob Zelin
  • David Telling
    November 16, 2006 at 1:18 pm
    You are right Bob, I did initially think this could be an AJA/Tempo SATA compatibility issue but it’s clearly gone beyond that. I thank the forum leaders for not objecting to this thread, but I will now close it.
    Thanks everyone….signing off!
  • David Smith
    November 16, 2006 at 2:24 pm
    David,
    While I certainly see Bob’s point about not continuing the OT thread here, I doubt I’m alone in saying I’ve followed the thread with great interest and a lot of wincing in empathy at your situation. When you have resolved things I sure would like to know what the problem(s) turned out to be.
    I would also like to say, as one who once snapped back pretty strongly when Bob’s “old” style of reply was directed at me, that we all here are very lucky to have such a knowledgeable and generous person taking a great amount of his time to help people on these forums. The fact that such system building and troubleshooting is how Bob makes his living (or so I gather) and yet he spends such a great amount of time advising people for free here, is truly impressive and a testimony to his nature. Thank you Mr. Zelin.
    Regards,
    David
