Activity › Forums › Apple Final Cut Pro Legacy › Update Another Dropped Frame on capture problem
  • Update Another Dropped Frame on capture problem
    Posted by Samuel Waldron on July 22, 2010 at 12:28 pm
    Hello and sorry if this s a re-post, please delete the earlier one as this is an update.
    I am running Final Cut Pro 6.0.6 and trying to capture from Canon XM2. A 1tb hardrive that I am using as the skratch and capture destination. It runs at 420Mbits/sec which I have read is fast enough(?)
    I have Mac OS X 3.06 GHz Intel Core 2 Duo 4GB Memory 1067 MHz DDR3 and using the firewire cable from 400 to 800 for capture.
    I am/was getting ‘dropped frames during last capture message’ I then disabled this to continue capturing. I am now getting “Capture uncounted a problem reading the data on the source tape. This could be a problem with the tape. Capture has been aborted and clip has been saved”.
    I am getting really desperate, any help please?
    Regards
    S
    Jeremy Garchow replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    July 22, 2010 at 2:45 pm
    Keep your posts together. It’s much easier to track.
    You need separate your FireWire devices. Get a fw express/34 card and attach your fw drive to that, then attach your deck to the computer fw port.
    Jerrmy
