Activity › Forums › AJA Video Systems › Upconverting via Kona – 29.97 Anamorphic DV to 23.98 DVC Pro HD
Posted by Barry Lank on September 14, 2007 at 4:43 pmI am having problems upconverting anamorphic 29.97 DV footage to 23.98 720p DVC Pro HD footage for use in a 720p 23.98 DVC Pro HD timeline. I have tried just about every combination in FCP as well as my kona 3 control panel and the footage I capture only seems to play back as slow motion.
When I try to capture/upconvert the sdi in in the kona contol panel reads 525 29.97 and is being upconverted to 720p 59.94… setting which are being pulled from FCP. What am I doing wrong?
Lu Nelson replied 19 years ago 5 Members · 11 Replies -
Walter Biscardi
September 14, 2007 at 4:48 pm[LankBeach] ”
When I try to capture/upconvert the sdi in in the kona contol panel reads 525 29.97 and is being upconverted to 720p 59.94… setting which are being pulled from FCP. What am I doing wrong?”You can’t change frame rates from 29.97 to 23.98 in the Kona. You would require something like a Terranex to do this.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Barry Lank
September 14, 2007 at 4:54 pmWould it work if I captured the DV footage as normal dv footage then converted it to dvc pro footage via compressor?
Walter Biscardi
September 14, 2007 at 5:45 pm[LankBeach] “Would it work if I captured the DV footage as normal dv footage then converted it to dvc pro footage via compressor?”
That will most likely look like crap. You really want hardware conversion for this process.
Barry Lank
September 14, 2007 at 5:55 pmWould it be a better idea to downconvert the hd footage to sd instead and just edit in an sd 29.97 timeline for the project? I have to mix dv footage with 23.98 dvc pro footage, as well as still images. the deliverable will be on a dvd so it will have to be converted to sd for that anyway.
Walter Biscardi
September 14, 2007 at 5:58 pm[LankBeach] “I have to mix dv footage with 23.98 dvc pro footage, as well as still images. the deliverable will be on a dvd so it will have to be converted to sd for that anyway.”
If you’re playing the DVCPro HD footage off a deck, then yes, simply capture the DVCPro HD to SD. The deck plays in 59.94 at all times anyway so you can simply capture from 59.94 to 29.97 SD.
Barry Lank
September 14, 2007 at 6:09 pmYeah, I knew that would work. I just wanted to see if there was an easy way to go from SD to DVC PRO because I already captured 5 tapes of the DVC PRO footage. I guess I’ll just recapture it in a downconverted format.
Thanks alot for your help!
Jeremy Garchow
September 14, 2007 at 11:49 pmI’d try compressor with a test clip, what’s the penalty?
If you turn on all the ‘best’ options, it’s going to take a while, but I bet you get decent results.
Jeremy
John Pale
September 15, 2007 at 12:56 pm[JeremyG] “If you turn on all the ‘best’ options, it’s going to take a while, but I bet you get decent results.
If you turn on all the ‘best’ options, it could literally take a week to render, depending on your machine. -
Lu Nelson
September 15, 2007 at 3:05 pmActually you should try compressor. it will take a long time but on a new computer it might work for you, and actually it does not look like crap it looks pretty good.
Barry Lank
September 17, 2007 at 1:08 pmI tried a 10 second test clip and it took 10 minutes on a 2×2.26 dual-core intel mac.
I had some other programs running while it was still converting but that is still pretty rediculous. might work if I leave all my clips converting over night.
