Activity Forums Apple Final Cut Pro Legacy upconverting to 720p, aspect ratio question
  • upconverting to 720p, aspect ratio question
    Posted by Nick Natteau on July 17, 2011 at 3:03 pm
    So I have a Kona LHi card, and I have a bunch of old WWII footage I’m upconverting from 480i to 720p.
    Now I see that AJA’s Kona LHi card has several aspect ratio options for upconverting 480i to 720p:
    • Anamorphic
    • Pillarbox 4:3
    • Zoom 14×9
    • Zoom Letterbox
    • Zoom wide
    Is it OK to upconvert using “Zoom wide” or is that not acceptable? Perhaps most people would use Pillarbox 4:3, but I was hoping to avoid the pillarbox look since all my interviews were shot in HD.
    Now I know that if I upconverted using the “Pillarbox 4:3” method, I could then zoom into the clips manually in my FCP7 timeline, but then I lose 33% of the upconverted footage above and below.
    So is it ok to use “zoom wide” in the broadcast world, or is that unacceptable? I know there would be a slight flattening of the image, but is that ok for distribution?
    Thanks in advance for feedback.
    Nick Natteau replied 15 years, 1 month ago 2 Members · 6 Replies
  • Shane Ross
    July 17, 2011 at 4:54 pm
    Zoom wide is fine. I typically do Pillar Box so that I can manually zoom in on the footage, because sometimes what I need to focus on is on the top or bottom parts of the frame. But you can do Zoom, Wide.
    Shane
  • Nick Natteau
    July 17, 2011 at 5:40 pm
    Hi Shane,
    Sorry my mistake I meant to ask if it’s ok to go Anamorphic (not zoom wide) when upconverting from SD to HD.
  • Shane Ross
    July 18, 2011 at 4:40 pm
    Test and see. That’s how I figure things out. But I am not sure as to the results. That option is really meant for SD footage that is already anamorphic I believe. You will still be cropping some of the image…or will be distorting it. Because 4:3 put into anamorphic…16:9…well, you still lose some image.
    Test and see.
    Shane
  • Nick Natteau
    July 18, 2011 at 5:00 pm
    Hi Shane,
    I meant is it ok for broadcast or distribution purposes for 4:3 SD footage to be flattened horizontally a little (via the Anamorphic upscale) when upconverting from 4:3 SD to to 16:9 HD?
    If I were doing it in FCP 7 for example, I would simply twiddle open the Distort tab and type “33.33” in the Aspect Ratio field to change the 4:3 aspect ratio to 16:9.
    I know it can be done, but broadcast wise / distribution wise, is it legit? Or do the rules say that aspect ratios must never be changed? That you can upscale and zoom in, but not distort 4:3 to get a 16:9 look.
    Just like luma or audio must never be too hot for broadcast, is it the case that aspect ratios must not be distorted as well?
  • Shane Ross
    July 18, 2011 at 7:16 pm
    [Nicholas Natteau] “I meant is it ok for broadcast or distribution purposes for 4:3 SD footage to be flattened horizontally a little (via the Anamorphic upscale) when upconverting from 4:3 SD to to 16:9 HD?”
    Ask the network. I have worked with one that wanted the footage 4:3 pillarbox, even though the rest of the show was 16:9 HD. I had one that wanted me to zoom in and fill the screen. And another that wanted me to keep the 4:3, but fill the black with a defocuses, enlarged image of the main footage. All different standards. Ask what they prefer. Also, do tests and see if it looks OK to you. 4:3 stretched to fill 16:9 doesn’t really look good….IMHO.
    Shane
  • Nick Natteau
    July 18, 2011 at 7:29 pm
    Thanks Shane will do. Just spoke to AJA Tech Support and they also advised against the 4:3 to anamorphic change. Also NoahK on the DVXuser’s FCP7 forum advised me to definitely change aspect ratio. From what everyone’s saying it sounds like it will cause me a lot of problems when it comes to distribution channels in the long run.
    I’ll take your advice and upconvert using Pillarbox 4:3 and then zoom in manually as needed.
    Thanks for your feedback.
