Activity Forums Blackmagic Design Upconverting SD options
  • Upconverting SD options
    Posted by Shane Ross on January 6, 2011 at 8:54 pm
    In the Blackmagic Control Panel, under PROCESSING, then INPUT PROCESSING…the options for SD to HD are 16:9 letterbox to HD, and 16:9 anamorphic to HD. Well, 16:9 in SD is RARE…über rare. What about the option for the MAJORITY of SD footage…4:3? Where is the option for that? What do you do when you have that footage?
    I want to capture 4:3 as PILLARBOXED…bars on the side. AJA allows for this. Matrox allows for this. BMD? Seems to lack this. Or, am I overlooking something?
    Shane
    Javier Sanchez replied 15 years, 8 months ago 3 Members · 3 Replies
  • Danny Hays
    January 7, 2011 at 12:01 am
    I’ve used that upconverting feature before, but with 16 x 9 SD video. I just tried with 4 x 3 and your right. With 16 x 9 letterbox checked, it chops off the top and bottom, with anamorphic checked, it streches the video to 16 x 9. I’ve personaly done away with all my SD cameras so I’m not effected by this. I use Sony Vegas mostly for my NLE and it gives me the option to take the streched to 16 x 9 clips and change the aspect ratio to get the pillar box results your looking for. It’s not a fix for BM lack of a setting for this but it’s a work around that works. Hope this helps,
    Danny Hays, Universal Studios FL
  • Shane Ross
    January 7, 2011 at 6:50 am
    I’ll try it and see. Just amazed that there is no setting for the standard format of SD…and only ones for the really rare ones.
    Shane
  • Javier Sanchez
    January 16, 2011 at 4:18 am
    Hi, are u using a mac or a pc? I want to up converting an sd signal to hd, on Pc is easy using the media express witch came with the bmd decklink 3d. But i install it on a mac to do it with final cut, however when i select on capture the blackmagic 1080i 59,94 i dont have image but if i set blackmagic ntsc, then i have.
    You know how i have to do it?
    Is for capture an Ntsc, telecine to HD upscaling with apple pro res codec…( with fcp )
    And one more, do i need a raid to capture it (bandwidth)?
    Regards
    and thanks a lot.
