Activity Forums Panasonic Cameras Upconverting beta footage with 1200a
  • Upconverting beta footage with 1200a
    Posted by Sean Fine on April 7, 2008 at 9:27 pm
    I need to upconvert beta sp footage and DV footage using my 1200A deck. My question is what is the best workflow. Can I basically use the deck as a go between without recording to Panasonic tape or do I have to record to tape and then capture that footage. Also any advice on menu setups would be really appreciated.
    John Sharaf replied 18 years, 5 months ago 2 Members · 1 Reply
  • John Sharaf
    April 8, 2008 at 4:59 pm
    Fine,
    The 1200A and 1400 decks will only upconvert through the firewire input port, do you should have no trouble with the DV materials, but as a work around, you’d need to dub the Beta to DV then upconvert.
    JS
