Activity Forums Blackmagic Design Upconverting
  • Upconverting
    Posted by Forrest Burger on February 24, 2007 at 6:55 am
    I have a DVCAM anamorphic master that I need to upconvert to DVCPro HD, then do some re-editing in FCP 5.1.2. I have access to a multibridge and a Panasonic AJ-HD1400. Is it possible?
    Forrest
    Forrest Burger replied 19 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 25, 2007 at 11:47 pm
    You’ll have 2 options. The AJ-HD1400 should be able to upconvert the SD tape so you can simply capture it with the Multibridge Pro or Extreme as an HD source. Any method available if you’re using the Mac Pro is to capture it as an SD source but up convert in real time to disk using the upconvert on capture option available in the DeckLink Preferences.
    regards
    Kristian Lam
    Blackmagic Design
  • Forrest Burger
    February 26, 2007 at 6:07 am
    Thanks, Kristian. It worked like a charm.
    Forrest
