Activity Forums AJA Video Systems Upconvert using Aja Kona 3 to DVCPro HD
  • Upconvert using Aja Kona 3 to DVCPro HD
    Posted by Shaun Lavery on May 1, 2008 at 12:31 am
    Ok… this is what I have. DVCPro tapes, a DVCPro 50 deck and Aja Kona 3 card and decklink. I need to take my DVCPro tapes and upconvert them to DVCPro HD. Is there anything else I would need for this upconversion?
    Arnie Schlissel replied 18 years, 4 months ago 3 Members · 3 Replies
  • Walter Biscardi
    May 1, 2008 at 12:47 am
    [Shaun Lavery] “Is there anything else I would need for this upconversion?”
    Nope, just make sure you understand how the AJA Control Panel works. This is where you’ll be setting up the Upconvert.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Shaun Lavery
    May 1, 2008 at 12:58 am
    Ok, thanks
    what do i need to do in the control panel for the upconvert?
  • Arnie Schlissel
    May 2, 2008 at 12:35 am
    You need to go from your DVC Pro 50 deck into the Kona 3 via SDI. You set the Kona 3 to upconvert in the Kona control panel, along with how you want the upconvert to be done- center punch, window box or stretch. Then, in FCP, you set the capture settings to DVCPro HD.
    For more info, you can access the help files in the Kona control panel.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
