Activity Forums AJA Video Systems Upconvert SD Letterbox to HD
  • Upconvert SD Letterbox to HD
    Posted by Tom Dempsey on August 6, 2012 at 1:33 am
    Hi, does anyone know if Kona has a way of upconverting letterboxed SD footage to full raster HD?
    Possible workflow?
    td
    tom dempsey
    Tom Dempsey replied 14 years, 1 month ago 2 Members · 2 Replies
  • Doug Beal
    August 6, 2012 at 3:06 pm
    select Zoom letterbox in the control panel for upconvert, select what you want to end up with in fcp easy setup, select the format you are coming from in the secondary format in the Kona control Panel.
    Capture the footage. it will be a little softer than if the SD footage was anamorphic
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Tom Dempsey
    August 6, 2012 at 4:50 pm
    excellent. thank you, i will try that.
    td
    tom dempsey
