Activity › Forums › Apple Final Cut Pro Legacy › Upconvert 720 to 1080
Posted by Steve Powell on July 11, 2005 at 9:52 pmI am editng a program that was shot with DVCpro100 720 24p. I need the final to be on 1080. Can FCP convert to 1080 60i?
I have: FCP 4.5 Dual G-5
Walter Biscardi replied 21 years, 2 months ago 2 Members · 3 Replies -
Walter Biscardi
July 11, 2005 at 10:50 pmYou don’t want to do that with Final Cut Pro because the scaling will reduce the quality. The two best ways to do this are:
Use the Panasonic 1200A to do the cross convert. You can set the menu in the 1200A to output a 720p project to 1080i.
Go to a facility with a Terranex box to do the cross convert. This box is found in film to tape / tape to film facilities or very high end post facilities. Here in Atlanta we have CineFilm, http://www.cinefilmlab.com, which handles projects from all over the country.
We’re currently doing the Terranex route on a series shot with the Varicam and being delivered via HDCAM 1080i.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Steve Powell
July 11, 2005 at 11:31 pmThanks, I am new to the HD world. I assume the Terranex box will do a better job than the 1200 deck.
Walter Biscardi
July 11, 2005 at 11:35 pm[Steve Powell] “I assume the Terranex box will do a better job than the 1200 deck.”
Just depends on your needs. I personally think the convert in the 1200A is broadcast quality. Our network specifies the Terranex so I have no choice and it does the best job. But the 1200A does do an outstanding job with the cross-convert.
