Activity › Forums › DVD Authoring › Up the Blu-Ray creek
  • Up the Blu-Ray creek
    Posted by Warren Gentry on September 13, 2007 at 12:01 am
    I think I’m up the blu-ray creek without a paddle. I bought a blu-Ray burner from FastMac and installed in my my non-Intel G-5 Mac. I bought Adobe Encore CS3 which only works on my Intel Macbook Pro. I bought Toast 8 which I installed on the same Mac as the blu-ray burner.
    So I author a blu-ray disc in Encore and output it as a Blu-Ray disc image. I then switch the drive over to the non-intel Mac and use Toast 8 to burn the disc using the VIDEO TS interface (much like I would do for a standard DVD) to a BD-R disc. I bought the Samsung BD-P 1000 player which claims to play BD-R discs. It does not play.
    My question is: Can you burn a blu-ray disc image as a data disc or in the Video-TS interface of Toast 8 and expect it to play anywhere?
    Thanks for any tips.
    Warren Gentry
    Max Kovalsky replied 19 years ago 2 Members · 1 Reply
  • Max Kovalsky
    September 19, 2007 at 11:51 am
    Warren,
    We have the BP-1000 and haven’t had any issues playing BD-Rs on it. Although we haven’t tried Toast, I know that it does support UDF file-system, so most likely you’re not setting up your directory structure correctly. There is no VIDEO_TS in BD but instead a BDMV in the root of your disc. Alternatively, see if encore can make an image. You can then burn it with ImgBurn, a free utility.
    Max
    Author
    Area 4
    New York
