Activity › Forums › Apple Final Cut Pro Legacy › Up-res/ Cross converting Cannon C300 720 slow motion to 1080
  • Up-res/ Cross converting Cannon C300 720 slow motion to 1080
    Posted by Dominique Guerette on April 11, 2015 at 3:26 pm
    Hi, I have a simple question and I can’t seem to find a simple answer.
    I shot some slow Motion with the cannon c300 therefore it is in 720.
    The rest of the footage in the sequence is at normal speed in 1080.
    So I would like to know the best way to cross convert/up-res the 720 slow Motion footage to become 1080 using only Compressor or mpegstreamclip or FCP.
    It would be greatly appreciated if you could guide me through the mots important settings to adjust to get the best result depending on the prefered software.
    David Roth weiss replied 11 years, 5 months ago 2 Members · 1 Reply
  • David Roth weiss
    April 11, 2015 at 5:30 pm
    If you’re not going to up-rez via hardware using a Teranex (best) or an AJA card, then just put your 720p footage on the 1080 timeline and scale if up top it fills the frame. It’ll most likely look great.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
