Up converting 1440×1080 footage
Hey Creative ones. Wicked forums, awesome resource – cheers for all the knowledge.
I have some footage shot on an older Sony HVR-A1P HDV Camera, which was captured using Final Cut Pro 6.0.1 on an older G5 (osx 10.4.11). This needs to be able to be dropped onto the same sequence as some footage from a newer AVCHD camera, with it’s footage imported using iMovie at full HD 1920×1080.
I’ve spent alot of time scouring the forums to learn about the HDV cams 1440×1080 HD footage and how it works with its non square pixels etc – I get that part. The part I’m having trouble with is up converting said HDV footage to 1920×1080 (to match the AVCHD footage). I’m using Apple Intermediate codec to save hard drive space (and because the old G5 won’t capture ProRes).
First, I tried using Mpeg Streamclip exporting it to AIC again, with 1920×1080 resolution, but this added jaggly little lines on the edges of things – a bit like interlacing, but not as severe. I also noticed the Data rate dropped from 103 Mbps down to 87 Mbps. Tried this on both older g5 and a newer Mac pro with the same results.
I then used Quicktime pro – this didn’t have the visible artefacts but suffered the same data rate drop – had the same result when exporting using QT directly from FCP.
This does solve my overall problem, in that the 1440 footage is now up to the larger 1920 size, and of course it drops into a timeline alongside the AVCHD footage nicely – but I’m concerned about the quality loss on the res up-convert. Why did Mpeg streamclip look so much worse, and why do both methods drop the data rate down so much? I would have thought exporting a file the same codec that it’s currently in would not affect the quality. If it looks ok, is the data rate drop anything worth worrying about? (before I got and batch convert 7 hours of footage…).
Cheers in advance from little old New Zealand.
