Activity Forums Maxon Cinema 4D Unwrapping a Ball
  • Unwrapping a Ball
    Posted by Tom Slattery on March 10, 2011 at 5:53 pm
    Hi!
    I’m wondering if C4D may be the good vehicle for this:
    I have art that I want to map onto a baseball. Easy enough, but I’d like to unwrap it to see how the art needs to be warped in order to print it correctly.
    ~TPS
    Tom Slattery replied 15 years, 6 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 10, 2011 at 8:50 pm
    Sure, it’s not too difficult. Basically it goes like this:
    1. Make your sphere editable;
    2. Switch to the body paint UV editing preset layout;
    3. With the sphere select, run Tools>Paint Setup Wizard;
    4. Make sure the sphere is checked and click Next;
    4. Uncheck “recalculate UVs and click Next;
    5. Use the default settings here, but change the swatch next to Color to white and click Finish;
    6. Now you should see your sphere’s UVs in the top-right window;
    7. Activate the Colors tab in the lower-left panel and choose black;
    8. In the layer menu (top or top-right), run the “Create UV Mesh Layer” command. That will automatically paint the edges black;
    9. Finally, Save you UV layer as a bitmap you can import into PS (File>Save Texture).
    hth
  • Tom Slattery
    March 10, 2011 at 11:22 pm
    Thank you!
  • Tom Slattery
    March 15, 2011 at 3:18 am
    Thanks again for those steps.
    I gave it a try and got to a point where I’m stumped. My model is the outer two ‘figure 8’ flaps of a baseball.
    The resulting UV image winds up being a square-ish image, which I am guessing is normal. What I’m trying to get to is how the image would look on the two parts when flattened out.
    ~TPS
