unwind a swirl
Posted by Doyal Gudgel on August 31, 2012 at 1:58 amHow do you unwind a swirl?
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.comDoyal Gudgel replied 13 years, 12 months ago 2 Members · 12 Replies -
John Rofrano
August 31, 2012 at 7:47 pm[doyal gudgel] “How do you unwind a swirl?”
Head in the opposite direction of the swirl. 😉
– or –
Keyframe the Amount parameter to be zero at some point in time.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Doyal Gudgel
August 31, 2012 at 11:13 pmHere are the only adjustments and none of them do an unswirl. Amount, 1.000 or -1.000 (direction). Scaling. Horizontal 1.0, Proportional
If selected disables or enables Vertical scaling. Maybe the preset selection has something to do with it. I am looking. -
John Rofrano
September 1, 2012 at 12:57 pm[doyal gudgel] “Here are the only adjustments and none of them do an unswirl.”
Did you try what I suggested?
Did that not unswirl?
What do you think that “unswirl” should do? (i.e., What effect do you want it to have?)
~jr
Doyal Gudgel
September 1, 2012 at 2:20 pmI want it to turn and as it turns reduce the swirl effect, The first time I added a swirl It turned like a disc but I don’t remember what I did to get the effect. Besides it was not quite correct. When it turns the swirl gets less and less until it is original picture. I thought this was the primary reason for a swirl.
John Rofrano
September 1, 2012 at 6:09 pm[doyal gudgel] “I want it to turn and as it turns reduce the swirl effect, The first time I added a swirl It turned like a disc but I don’t remember what I did to get the effect.”
Perhaps you use Pan/Crop to rotate the frame as you applied the swirl?
[doyal gudgel] ” When it turns the swirl gets less and less until it is original picture. I thought this was the primary reason for a swirl.”
Yes, and that’s what happens when you keyframe the Amount parameter to go from 1.0 to 0.0 as I suggested in my original reply. Did you try that?
~jr
John Rofrano
September 2, 2012 at 1:44 pm[doyal gudgel] “No how do you do that?”
With keyframes. Do you know how to set keyframes for an FX?
~jr
Doyal Gudgel
September 2, 2012 at 2:20 pmNo, I looked for “Keyframes in help but it didn’t help me whatever it said. Too bad I didn’t get serious about Sony Vegas some years ago instead of messing with the hacked version.If I had just gone and bought a legal one I would not be trying to do my film and pictures now that I am going blind.
This is fun. If I look, what I want to do, they have already thought of it. Really amazing. This swirl is not important but for the fun of it I would appreciate how to unswirl it. Have a nice day.
John Rofrano
September 2, 2012 at 2:58 pm[doyal gudgel] “No, I looked for “Keyframes in help but it didn’t help me whatever it said.”
OK, let me use an analogy that my good friend Douglas Spotted Eagle always uses: Keyframes are like appointments on your calendar; e.g., at 10:00 you need to pick up the dry cleaning, at 11:00 you need to pick up the kids, etc. They are points in time that something should occur.
You want to tell the Swirl FX that at 00:00:00;00 you want the Amount to be 1.0 (full swirl) and at 00:00:01;00 (one second later) you want the Amount to be 0.0 (no swirl).
You do this by setting keyframes on the little timeline at the bottom of the FX window. In the screen shot below, I’m using Movie Studio Platinum 12 so your Movie Studio may look different but it will behave the same. Since the first keyframe is always there, all you need to do is create a second one. Move the little timeline cursor out to the 1 or 2 second mark and change the value of Amount and a new keyframe will automatically be created at that point with the new value. Like this:
That will make the swirl… unswirl.~jr
Doyal Gudgel
September 3, 2012 at 12:57 pmOK thanks for taking all that time to answer my question. Depending upon the setup of my window sometimes things are not visible and have to be located. That can take a lot of time. It finally works. I owe you one. I have posted a few seconds on youtube if you want to see what it is all about. It has some stuff google probably does not like so it may not stay there very long.https://www.youtube.com/watch?v=jtyovI4bvXo&feature=youtube_gdata
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
