unwanted speed changes on footage in FCP after capturing from XML
Hey,
Here’s the backstory to this problem that no one at my work has seen before or can figure out why it’s happening.
We shot some spots on HDCAM SR and loaded the tapes, 1080p/23.98, with wrong reel numbers into FCP. I am working on FCP 6.0.5 with Kona2 card. The editor worked on the cuts and we will be outputting for Smoke soon. We straight copied the project to a new drive to do some tests and changed the reel names in the browser on the tapes that were incorrect. We read that that was the way to change the reel names but felt like it was too simple of a procedure to change some metadata that’s pretty important.
I exported an XML for a sequence that has footage from the newly re-named tapes to see if it would recognize the proper tape in a new project and also capture it. And it did.
Here’s the problem. When watching that footage in the viewer window and in the sequence, it plays it at like 300% speed even though there is no speed ramp or time changes to any of the footage, people are just flying around and now the actual footage in the sequence is all thrown off. To note, the original sequence had a slight speed up of the footage, but no where near as drastic as what is being captured from the XML in the new project. The actual capture scratch QT is fine, it’s when its played in Final Cut is when it’s all sped up. I’ve tried on different machines and re-booted, always the same problem.
Why is this happening, I guess is my question, and is there a way to fix it so its just normal speed?
Let me know if anyone has any thoughts. Thanks.
