Activity Forums Adobe Premiere Pro Unwanted pixels when rendering vector graphics
  • Unwanted pixels when rendering vector graphics
    Posted by Søren Thomsen on March 12, 2008 at 1:21 pm
    I have in many projects used vector graphics, but when I render the movie unwanted pixels appear at the top of some of the vector elements.
    I use Premiere cs3 and I have tried using .eps and .ai files as vector graphics – both with the same outcome.
    Heres is an example (the circle is added afterwards)of my problem:
    https://www.attention8.dk/preview/videoProblem.jpg
    I’m sure that the pixels does’nt exist within the .eps/.ai file because I have experienced it with both “homemade” vector graphics and from Logos from various companys.
    I’m looking forward to your replies.
    Thank you in advance.
    Jon Barrie replied 18 years, 6 months ago 3 Members · 2 Replies
  • Joseph Springer
    March 12, 2008 at 4:02 pm
    Just act like you put them there for artistic flare ; )
    JK. I am curious, are the unwanted pixels always the same color as an element of the vector?
    Regards,
    Joe Springer
    Certified Adobe After Effects Training and Premiere Training Instructor
  • Jon Barrie
    March 12, 2008 at 11:15 pm
    I had experience with a similar problem where a client supplied the file with outlined text. they had a white BG they didn’t want. So as i deleted it I found heaps of other junk in the white BG. So I put Illustrator in View Transparency Grid and could see all the crap. Once I cleaned it up there were still some bits coming through on the top of the frame. So I added a clear box behind the text bigger than its own bounding box size. That seemed to fix it.
    This was all on a mac version of PProCS3. The issue didn’t seem to be there in my PC version. If the text isn’t doing anything then why don’t you use it as a PSD file? Then replace it in the timeline.
    This is a typical AE looking project for me – AE doesn’t have any issues with Vector Graphics.
    Hope my story helps.
    – Jon 🙂
    How many editors does it take to change a light bulb?
