Activity › Forums › Adobe After Effects › Unwanted layer changing
  • Unwanted layer changing
    Posted by Bradley Howard on January 18, 2009 at 8:37 am
    Ok… see if I can explain this properly.
    For example…. Say I am using Primatte keyer…. I will click in the effects tab, select which parameter I want to adjust, do my adjustment on my canvas, then when I go to select another parameter in the effects tab… it will automatically change to a different layer… I then have to select the layer I was working on, go back to the effects tab, select which parameter i want to adjust, go to the canvas and do the adjustment, and then back to effects tab to select next parameter and it automatically changes to a different layer… increasingly frustrating and probably not explained well enuff
    Bradley Howard replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
