Activity Forums Adobe After Effects Expressions Unwanted dockable popup
  • Unwanted dockable popup
    Posted by Brendon Murphy on October 12, 2020 at 8:19 pm
    I have a dockable UI with buttons that are set up to call upon other scripts through app.findMenuCommandId(). The scripts work correctly when each button is clicked. However, an empty docking window always pops up with the name of the external script that was run.
    Has anyone run into this? I don’t want to use $.evalFile() because it never lets my Sample Image expressions draw properly.
    Also, this is in CC 2018.
    Brendon Murphy replied 5 years, 10 months ago 1 Member · 1 Reply
  • Brendon Murphy
    October 12, 2020 at 8:27 pm
    Well, should’ve worked on it for another two minutes. Turns out there was a duplicate copy of my external scripts in the ScriptUI Panels folder. My UI was calling upon those, instead of the versions I had intended.
