Activity Forums Adobe After Effects unwanted cropped effect in composition, using transform effect.
  • unwanted cropped effect in composition, using transform effect.
    Posted by Jeremy Buttell on February 27, 2010 at 12:35 am
    Hello everyone,
    I have a transform ‘effect’ on an animated element (simple shape moving from bottom to top of screen and beyond) that extends roughly about 2x the height of the composition height. I’m using the transform effect to try and get shape to sort of continue it’s movement once it exits top of frame to continue through the bottom of frame (well, not exactly the bottom, but roughly)
    I’m working on some texture animation that’ll be ultimately mapped to UV space in 3d/Maya, so I’m trying to hack the animation to bridge from one part of the UV page to another.
    Unfortunately, the transform effect seems to only transform about 10-15% of the shape-animation. In other words, it seems to be cropping the image about 10-15% outside the composition window. Is there some sort of global setting/preference I can adjust to allow rendering beyond this point, so my transform will ‘rollover’ from the top of frame to bottom properly?
    thanks for any insight into this.
    Andy George replied 16 years, 6 months ago 3 Members · 4 Replies
  • Andy George
    February 27, 2010 at 1:23 am
    Hi Jeremy,
    Can you provide more details about how you are
    achieving the “rollover” effect. I’m not sure how the
    transform effect would do this on it’s own, unless your
    applying it to multiple similar offset layers.
    [Jeremy Buttell] “In other words, it seems to be cropping the image about 10-15% outside the composition window.”
    Do you mean the image is cropped inside the composition window?
    If it’s being cropped outside the window how can you tell?
    If I had to take a wild guess I would say that your problem is coming from
    something that has been precompesed. Can you provide some more details about
    how your composition is set up?
    -Andy
  • Jeremy Buttell
    February 27, 2010 at 1:44 am
    Yes, it isn’t a perfect solution as I’d have to duplicate the layer that’ll receive the transform effect.. the idea would be the appearance that the one shape is continuing to move through a different portion (sort of a teleport) of the composition. In my setup, it isn’t a single layer that’s doing this, that would be ideal though, saving me some time.
    As far as the composition setup. All elements in question are AfterFX generated – the primary one being a rectangle shape. I’m animating it traveling bottom to/through and well beyond the top of frame. I’m then duplicating the layer, then applying the transform offset effect. I’m not specifying any compression/rasterization that I’m aware of.
    I’m trying another idea to get around this, though still not entirely ideal, where I have a master offset defined (just using a dummy layer’s xform properties). For the shapes that I want to inherit this xform, I’ve added a simple expression that points to the master offset dummy layer. This of course still requires that I duplicate layers for this apparent continuation/rollover. Once I finish doing the animation, I’ll just duplicate everything, then apply this offset. I wish there was a more elegant solution, but this is the best thing I can think of with my limited understanding of after effects.
    Regardless, I’d like to know why the image gets cropped when using the transform ‘effect’ ….or probably any other effect. I mean, I’m pretty certain it crops it for performance, but it typically seems like a preference one would have access to.
    thanks for the reply.
  • Joey Foreman
    February 27, 2010 at 1:51 am
    Sounds like Motion Tile would be more appropriate for what you’re doing – if I do understand what you’re doing – which I’m not sure I do.
  • Andy George
    February 27, 2010 at 7:57 pm
    Hi Jeremy,
    Ok I understand. Your first method would work if you precompose the animated
    layer into a comp tall enough to accommodate the animation. Then in your main
    comp just duplicate the precomp, and offset the duplicate in time and space.
    Here is a cs4 example-
    https://www.chiselindustries.com/Client/rollover.zip
    Easy enough as long as you don’t have to do it 100 times-
    [Jeremy Buttell] “Regardless, I’d like to know why the image gets cropped when using the transform ‘effect’ ….or probably any other effect. I mean, I’m pretty certain it crops it for performance, but it typically seems like a preference one would have access to.”
    I don’t know the inner workings well enough to be supremely confidant about this but
    hopefully someone will correct me if im wrong.
    I would assume your correct in thinking that after effects does not calculate what’s
    outside of a camera’s or 2D compositions boundaries, although Since precompositions always render first,
    the information is going to be available wherever it sits in your main comp.
    -Andy
