Activity Forums Adobe After Effects unwanted contrast correction flicker
  • unwanted contrast correction flicker
    Posted by Scott Mcauliffe on April 6, 2006 at 4:17 pm
    I’m working with a bad VHS source that needs to have its contrast adjusted. I used the Shadow/Highlight filter which seemed to work, but when I rendered it out there was an occasional “flicker” or “flash”. I think I narrowed the issue down to having my Temporal Smoothing setting at zero. When I moved it to 2 or 3 the flicker dissipated but my render time significantly increased for my 1GHz G4 powerbook.
    So, is there a way to correct the contrast without significantly upping your render time? Is using the Shadow/Highlight filter a preferred method for contrast adjustment?
    thanks,
    – scott
    Scott McAuliffe
    Urchin Multimedia Design
    http://www.urchinmultimedia.com
    http://www.pbase.com/smcaulif
    Scott Mcauliffe replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
