Activity Forums Adobe After Effects Expressions unsynch a ‘loopout’ on multiple layers … possible?
  • unsynch a ‘loopout’ on multiple layers … possible?
    Posted by Jerry Fines on March 18, 2008 at 12:51 am
    hi,
    I made a very simple position animation and looped it. The exact code is:
    loopOut(“cycle”, 3)
    I applied it to a many layer, but realize I don’t want the cycle uniform on every layer (ie: I don’t want them to all animate in sync – I would like the sync to be ‘off’ a little). I was wondering if there was something I could add to the expression to do that? Right now my only option is to move each later a little on the time line however that would prove very time consuming. Thanks in advance for any help.
    -Jay
    Dan Ebberts
    replied 18 years, 6 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    March 18, 2008 at 3:32 pm
    You could “roll your own” loop out expression and vary the timing, like this:
    loopKeys = 3;
    seedRandom(index,true);
    variance = random(-0.2, 0.2); // time variance (seconds)
    t = time + variance
    t2 = key(numKeys).time;
    t1 = key(numKeys – loopKeys).time;
    if (t > t2){
    valueAtTime( (t-t2)%(t2-t1) + t1)
    }else{
    valueAtTime(t)
    Dan
  • Jerry Fines
    March 18, 2008 at 6:19 pm
    Wow Dan, thanks that really worked! It’s true you guys definitely know what you’re doing here!
    I was wondering, just out of curiosity, would it be possible to also change the ‘speed’ of the aforementioned loopOut? In other words, now that I have them all slightly unsynced, would it be further possible to make some loops go faster/slower then other loops using an expression code?
  • Dan Ebberts
    March 18, 2008 at 6:36 pm
    Somethingk like this, maybe:
    loopKeys = 3;
    rateMult = random(0.75,1.25); // rate multiplier
    t = (time + variance)*rateMult;
    if (t > t2){
    }else{
    valueAtTime(t)
    Dan
