Activity Forums Adobe Premiere Pro “unsupported format or damaged file” when importing tiff sequence
  • “unsupported format or damaged file” when importing tiff sequence
    Posted by Noland Orozaco on October 13, 2012 at 10:02 am
    Hi there,
    I’m getting the error “unsupported format or damaged file” when I try to import a tiff sequence.
    I’m importing them by going to file>import
    Then I select the files and check “Numbered Stills”
    Here’s some info on the tiffs
    Dimensions: 1920×1080
    Horzontal and vertical resolution: 96 dpi
    bit depth: 48
    Compression: Uncompressed
    11.8MB Filesize
    I can open these tiffs in photoshop, Windows Photo Viewer, and After effects, but not Premiere.
    Any ideas why I’m getting this error message?
    What can I do to the tiffs so that Premiere will take them?
    Noland Orozaco replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
