Activity Forums Adobe Premiere Pro Unsupported compression error
  • Unsupported compression error
    Posted by Randal Johnson on July 6, 2005 at 7:31 pm
    When I try to open some avi’s I get an Unsupported compression in file error. I’m using Premiere 1.5. I’d like to know how to deal with this? Can I get the codec/compression scheme somewhere to install on my machine or what do you need to do? I appreciate any advice.
    Randal
    Aaron Strader replied 21 years, 2 months ago 3 Members · 2 Replies
  • Tim Kurkoski
    July 6, 2005 at 9:26 pm
    The first important question is what codec do these AVI files use? You will need to have that codec installed for it to work.
  • Aaron Strader
    July 6, 2005 at 10:49 pm
    And if you don’t know what codec you’re using, check out this program. It’s got a HUGE list of AVI/audio/MPEG codecs to tell you what you need loaded to get it to work.
    https://www.headbands.com/gspot/
    It is called GSpot, and it’s an awesome program.
