Activity › Forums › Adobe Premiere Pro › Unsupported Audio Rate
  • Unsupported Audio Rate
    Posted by Shawn Cash on August 22, 2008 at 5:22 am
    OK … So I have a Sony DVD recorder and had a terrible time trying to import files into Premiere … Finally got the Roxio Easy Media Creator 10 to convert the files to mpeg. Now when I try and bring them into Premiere I get “Unsupported Audio Rate Error” and nothing gets imported … not even the movie. How on earth do I get around this??? I’m kind of under a time crunch … this darn thing wasn’t supposed to be this much trouble. Silly me I thought using a DVD recorder would have made things easier!
    Vincent Rosati replied 18 years ago 3 Members · 3 Replies
  • Ann Bens
    August 25, 2008 at 3:43 pm
    A matter of fact a dvd recorder makes things worse. Premiere does not take kindly to mpeg.
    To which audio format did you convert, the best format is .wav.
  • Shawn Cash
    August 26, 2008 at 5:48 am
    Whatever the default is for Sony …never seen it before POV … PV … don’t have it in front of me. I know the Roxio program will convert to multiple formats … I am trying to convert the video and audio together … thought I could do that with mpeg, but Premiere won’t let me import it. Should I chose a deferent video format other than mpeg? Do I have to try and seperate out the audio from the video and import them both on their own?
  • Vincent Rosati
    September 3, 2008 at 12:43 am
    Usually for import issues simply decompressing the files works – Codec: Uncompressed or Compression: None.
    I use AVS Video Converter.
    For audio, PCM WAV is nice.
    Vince
