Activity Forums Apple Final Cut Pro Legacy Unstable image
  • Posted by Michael Calvino on February 14, 2006 at 11:43 pm
    Recently FCP has doing wierd things…
    When I rescale an image over time the graphic
    seems to jump around and not a smooth movement
    like it used too…
    also when I dissolve a text in the image also jumps a little,
    but also enough to make it unusable..
    pls hlp
    Ben Insler replied 20 years, 2 months ago 2 Members · 1 Reply
  • Ben Insler
    February 15, 2006 at 12:47 am
    Just to be sure, you’re rendering your image and text effects, right? If this is not new information then I apologize, but at the top of your timeline, there should not be anything but gray or dark blue render flags if you want to view full quality, full res playback. If these are there, make sure that you turn all your render flags ON under “Sequence:Render Selection” and “Sequence:Render All”
    If that’s not the problem, please continue this post.
    Best,
    Ben Insler
    Editor
    Telemark Films
