Activity › Forums › Apple Final Cut Pro Legacy › unspecified path
  • unspecified path
    Posted by Federico Stagi on September 3, 2010 at 1:56 pm
    Hi, I don’t speak english very well, but i’ve a problem, so I try.
    I work on FC 6.0.6
    i create a batch list, import in final cut and batch the clip generayed by my batch list.
    Then I copy the file captured on a second mac, import the same batch list in an other prj on the second mac, selecte the clip of the batch list and choose reconeect media.
    At this point begin the problem: in the reconnect files window appear “unspecified path” and I could only reconnect each clip one by one.
    Does anybody know how can I reconnect the clip at once?
    thanks
    Federico Stagi replied 16 years ago 2 Members · 2 Replies
  • Paul Cotton
    September 18, 2010 at 5:09 am
    This appears to be an ongoing bug with FCP. I just got around it by dragging all the offline files and sequences into a new sequence. then highlight the entire sequence and choose export xml from the file pull down menu. Save the new file when prompted, open it, reconnect all the media in one shot. I think you lose transitions in the sequences but everything else seemed to work well.
    Hope this helps.
    Cheers
    Paul Cotton
  • Federico Stagi
    September 22, 2010 at 7:00 am
    I’ll try, thank you
