Activity Forums Adobe After Effects unspecified avi or directshow error?
  • unspecified avi or directshow error?
    Posted by Justa2007 on June 19, 2007 at 9:36 am
    can any one help me with this.
    unspecified avi or directshow error in afx 7
    it come up when i am rendering.
    i also get hit with unspecified drawing errors
    and image buffer errors. help please!
    i have 2 gd ram and a2,4ghz 6600 intel
    vista ultimate with the lates updates
    HI
    Smirnoff Black replied 18 years, 11 months ago 5 Members · 4 Replies
  • Roland R. kahlenberg
    June 20, 2007 at 3:33 pm
    Why o why did you install Vista??? It sounds like an early adopter problem. I’d try to test the AEP on an XP machine just to make sure.
    Good Luck
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects Project Files
    https://www.myspace.com/rorkrgbspace
  • Brendan Coots
    June 21, 2007 at 1:56 am
    Make sure you have the latest (and correct) driver for your video card. Even if you have OpenGL disabled driver problems WILL generate unspecified drawing errors and the like.
    Like the other poster mentioned, Vista might be your problem as well.
  • Theo Brown
    September 19, 2007 at 8:06 pm
    Hello, I may have found a solution — at least it solved it on my end. When I tried rendering out at 720×486 using the Matrox codec, I got the AVI & Direct Show Error message too.
    However, I changed my comp size to 720×480….and voila! It rendered, no problems at all.
  • Smirnoff Black
    October 5, 2007 at 1:35 pm
    I’m getting the exact same error message in After Effects 7 at the moment and I’m using Windows XP SP2. Here’s exactly what it says…
    After Effects error: an unspecified AVI or DirectShow error occured. (1)
    (53 :: 33)
    I get the error when trying to import footage, I’ve tried different mpg and Hi def footage and still get the message. I can still import wmv and Quicktime footage though.
    Also, I was working on some 3D the other night, went to move the camera on the Y-axis and, again, kept getting the error message, although I can’t remember if it was the same error as the one above. I think it said something about OpenGL.
    I’ve de-installed After Effects, run CCleaner to get rid of any remnants of it. Then re-installed but keep getting the error.
    I then installed After Effects onto my laptop which also runs Windows XP SP2 and tried importing the same mpg and Hi-def footage as I had tried on my desktop and, voila, it worked!
    So, any ideas what the problem is?
    My system is
    Intel Quad Core Q6600
    4Gb Corsair 6400 DDR2 RAM
    Asus P5K Deluxe Motherboard
    Nvidia 7800 GTX Graphics Card
    Windows XP Sp2
    I also have a dual monitor set-up which I only got recently. Could that be the problem? Never had this problem with AE before.
