Unsolved questions about Adobe Encore CS5.1
Hello Everyone,
I need your help to understand why a M2t file generated by Premiere Pro CS5.5 and import into Encore CS5.1 is found in a folder BDMV STREAM 000000.m2ts with a bitrate and size lower than the original even though there was no transcoding.
Here are some additional details :
M2t file :
1.92 Go
00:07:34
35885 Kbit/s
1920×1080
23,976
H.264
Ac3 448 Kbit/s
48KzThe file has been imported only in and then a blu-ray iso file has been generated. No menu or additional audio track was added.
For the parameters of the project in Encore, I selected Blu-ray, ntsc, 40 Mb/s, H.264, 1920×1080, 23.976 and Dolby Digital.
In project, I clicked on the M2t file, properties and I selected “don’t transcode”.
And finally, I generate an image file with 50Gb as a parameter.
Encore estimated the size to 2.17 GBThe time required to duplicate the file (no transcoding) and creates the image file took only 30 seconds.
Size of image after creating the file is only 1.68 GB
After mounting the file to a virtual drive and going into the folder BDMV STREAM
The m2ts video file is different from the original.
Original M2t vs M2ts :
1.92 GB vs 1.68 GB
00:07:34 vs 00:07:33
35885 Kbit/s vs 31702 Kbit/sThis is the crux of the problem.
I also want to draw your attention to the fact that the Mt2 file was created with Premiere Pro CS5.5 with a footage from DSLR.
MOV files from the DSLR have an average bitrate of 25000 Kbit/s.I compared frame by frame the two videos (.mt2 and .mt2s) with a zoom of 300% and I see no difference!
Thank you for your help and sorry for my English.
