Activity › Forums › Apple Final Cut Pro › Unsigned Big PCM
Unsigned Big PCM
Posted by Eddie Valentin on November 13, 2025 at 6:21 amHow do i get Unsigned Big PCM audio is it one of the pro res? It keeps coming out as little / signed
Eddie Valentin replied 10 months ago 3 Members · 4 Replies -
Mads Nybo jørgensen
November 13, 2025 at 8:14 amHey Eddie,
Sorry, but you need to give a bit more context, as ProRes is normally a codec only used for video and audio together.
What do you have in your timeline, and what is it that you need to deliver?
PCM audio like video can sit inside a number of different types of file “containers”, although it may involve a “conversion” to a lower quality format.
Mads -
Eddie Valentin
November 14, 2025 at 5:24 amI attached .txt of a .mov with pcm linear video I rendered with and view media info. please check under audio. Why in format settings its little/signed? Please help me change format settings to unsigned big pcm audio to me I’ve noticed that unsigned big pcm or sounds louder.
Ben Balser
November 14, 2025 at 1:59 pmAs this was answered in the Apple forum, there’s no volume difference between the two audio codecs you’re referring to. Changing from one to the other will NOT have any influence on the sound level. That is purely determined by the gain settings during the source recording and/or the mastering in the edit. But if you needed to do this, and it would make zero change in volume (I’m retired audio engineer), you should look at creating a custom preset in Compressor (if it’ll even let you do that).
