Activity › Forums › Apple Final Cut Pro Legacy › Unrendered warning
  • Unrendered warning
    Posted by Dylan Green on August 26, 2005 at 10:03 pm
    For some reason whenever I go to play a clip on the timeline it says “unrendered”. This just started happening and does so even if I insert a single shot (no transition, effect, etc.). Any ideas why this is happening?
    Dylan
    Tony! Hulette replied 21 years, 1 month ago 3 Members · 2 Replies
  • Sean Lander
    August 26, 2005 at 11:30 pm
    You have either inadvertently moved the vision a little bit or your footage has been mismatched with your timeline compression settings. ie. editing DV into a sequence set up for Uncompressed. To check for motion double click on the clip that is unrendered loading it into the viewer. Now look at the motion settings to make sure nothing is abnormal. If it is, again click on the unrendered clip and hit APPLE 9 and look at the properties of it. Close that window and now hit APPLE 0 to see if the Timeline settings are the same.
  • Tony! Hulette
    August 26, 2005 at 11:31 pm
    Your capture settings (the clips codec, size, etc) probably don’t match your sequence settings exactly.
    Tony!
