Activity Forums Adobe Premiere Pro Unrendered audio in Premiere will create a slow export in Adobe Media Encoder
  • Unrendered audio in Premiere will create a slow export in Adobe Media Encoder
    Posted by Paul Nicholson on October 2, 2019 at 9:28 pm
    This is a problem I discovered after a lot of research. If your entire audio sequence is not rendered after you’ve played with the audio in your project, you will get a slow export in Adobe Media Encoder. This includes audio outside of the work area. If its not done in Premiere, AME will try to do it – and it cant handle it. It will either take hours or crash or both.
    Paul Nicholson replied 6 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
