Activity Forums Adobe Premiere Pro Unrecognised audio by Premiere Pro
  • Unrecognised audio by Premiere Pro
    Posted by Mike Kann on November 17, 2016 at 6:44 am
    Weird Problem
    I have just recorded my screen as an MP4 with an MPEG4 codec, playing the video back all works fine: the video is goo, computer audio good, computer mic good. It plays back fine in every video player but as soon as I put it in Premiere Pro CC 2015.3 it says the clip has no audio.
    Similarly trying to open it in Adobe Audition it says it is a clip with no audio.
    I opened the clip in PluralEyes and that played with audio but then when I export it into an FCP format for PP, opening this in premiere takes the footage offline then when re-linking says it has no audio.
    Converting the files in Media Encoder has not had any success, nor has re-recording the footage with H.264 codecs. Previous versions of PP have the same problem.
    I have tried lots of solutions from threads that are similar but nothing seems to be quite the same as this.
    Any Ideas from anyone?
    Cheers
    Mike Kann replied 9 years, 9 months ago 3 Members · 3 Replies
  • Daniel Waldron
    November 17, 2016 at 2:02 pm
    How long is the clip?
  • Ann Bens
    November 17, 2016 at 2:50 pm
    Convert with Handbrake and also set it to constant framerate and try again.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Mike Kann
    November 17, 2016 at 9:14 pm
    Fixed! Thank you very much Ann Bens.
    Using Handbrake to convert it to a constant frame rate has fixed the problem.
