unpredictable valueAtTime proj
Ive uploaded my project since this would be a little complicated to explain. Basically i have a bunch of layers with some basic reference/offset expressions on them creating the effect you see. The problem came when i added a valueAtTime to the x,y…the layers are referencing each layer index-1 for Z space offset and index+1 for x,y since i want to animate the bottom one and have the rest above in layer order follow. But im getting unpredictable, inconsistent results…almost a different result in each playback, some will follow one time but stop following a few layers up, some positions are just offset completely wrong.
“Layer 15” has the key frames on it, so when i scrub before the keyframes and play from there youll see the different results im talking about. Thanks for the help as always.
link to file: Project file is AE CS4
