Activity Forums Adobe After Effects Unmult plugin for old AE comp (AE CS 5.5)
  • Unmult plugin for old AE comp (AE CS 5.5)
    Posted by Quen Hoai on September 17, 2020 at 8:43 am
    Hi all,
    I need reopen a comp, which made in AE CS 5.5 and have apply Unmult plug-in. I always get the error message Unmult even though I have installed Unmult (2019) for AE CS 5.5.
    What wrong for me and How can I fix it?
    Thank for your advice.
    Quen Hoai replied 5 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
  • Michael Szalapski
    September 17, 2020 at 11:59 am
    Why not just replace the instances of the old effect with the one you have installed?
  • Quen Hoai
    September 17, 2020 at 1:25 pm
    Thank for your answer and I tried but maybe unmult not support for AE 2018 on window 10. Did you have any other advice?
  • Walter Soyka
    September 17, 2020 at 1:39 pm
    What exact version of Unmult have you installed (there are a number of them, maybe you can provide a link to the one you’re using)?
    What exact error message do you get?
  • Kevin Camp
    September 17, 2020 at 10:07 pm
    You could try replacing Unmult with a couple standard effects.
    This is what I started using when Unmult stopped being free briefly about a decade ago.
  • Walter Soyka
    September 17, 2020 at 10:36 pm
    Good call, Kevin. I actually wrote a script a few years back to “UnUnmult” a project, replacing the Red Giant effect with a couple of different options:
    http://www.renderbreak.com/2014/10/keen-ununmult-a-workaround-for-the-unmult-bug-in-ae-13-1-cc-2014-1/
  • Chris Wright
    September 22, 2020 at 8:30 am
    Just roll your own. It does the same thing and work in any AE version.
    To use the Set Matte effect you need to first pre-compose your lens flare on the black solid layer and move all attributes to the new pre-comp.
    Then apply the Set Matte effect to the pre-comp in your main comp and change the “Use For Matte” property to luminance or lightness.
    Then change the pre-comp’s blend mode to “Luminescent Premul.”
  • Quen Hoai
    October 27, 2020 at 8:00 am
    thank you and will let you know my try.
  • Quen Hoai
    October 27, 2020 at 8:01 am
    thank you very much, sorry my late but I will try your way.
  • Quen Hoai
    October 27, 2020 at 8:10 am
    thank you very much Kevin.
