Activity Forums VEGAS Pro Unmasking Masking
  • Unmasking Masking
    Posted by John Perez on September 11, 2021 at 8:29 am
    I have two tracks. In the top track I want multiple cut-out so I can see through to the track below. The first cut-out using the masking tool is fine but anymore cut-outs, they only show black, not the track below. How do I make more than one cut-out on the same event? Thx…
    Red-rob Rothkopf replied 4 years, 11 months ago 2 Members · 1 Reply
  • Red-rob Rothkopf
    September 11, 2021 at 6:26 pm
    Hey John!
    Are you using the masking on the Pan/Crop tool, or a different way of applying a mask?
    You should be able to create multiple splines/masks to select different parts of your image using the Pan/Crop’s masking without any problem. You also probably could apply a cookie cutter effect but that’s way less flexible.
