unlocked clip
Posted by John Culleton on October 21, 2015 at 10:35 amim using a clients laptop with ver10 and clips shot on a Sony EX3 wont group, audio and video wont group, this is wierd, i still use ver9, so is this a ver10 bug?
John Rofrano replied 10 years, 10 months ago 2 Members · 9 Replies -
John Rofrano
October 22, 2015 at 2:52 amMake sure that you don’t have Ignore Event grouping enabled. if you do, grouping will be ignored.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
John Culleton
October 22, 2015 at 9:48 pmthis is audio and video clips not ‘locked’, they come onto the timeline as seperated audio and video tracks and nothing will lock them together. i have to cut the video and audio track individually.
John Rofrano
October 23, 2015 at 1:01 amDid you toggle Ignore Event Grouping? (Ctrl+Shift+U) What was the effect of that? It really sounds like you have Ignore Event Grouping enabled.
~jr
John Culleton
October 23, 2015 at 8:09 amignore event grouping made no difference, i dont have the laptop now so cant check, maybe it was the way the clips were imported? i had to import them from a card reader through a utility, i cant remember what the utility was tho?
im gonna take my laptop next time, thanks for the replies
John Rofrano
October 23, 2015 at 11:53 am[John Culleton] “i had to import them from a card reader through a utility, i cant remember what the utility was tho?”
Why didn’t you use the Vegas Pro Device Explorer? That’s how you should be importing footage from a camera card.
~jr
John Culleton
October 23, 2015 at 12:23 pmAH!! my HP laptop has an express card slot which i use to import SxS footage, so ive NEVER used device explorer.
the clients Alienware (Dell) laptop has the USB card reader, so maybe Vegas auto uses Device Explorer?
John Rofrano
October 24, 2015 at 1:18 pm[John Culleton] “my HP laptop has an express card slot which i use to import SxS footage, so ive NEVER used device explorer.”
Have you tried the Sony Creative Software SxS UDF Driver software? This enables read/write of MXF files recorded in UDF mode on SxS memory cards.
~jr
John Culleton
October 27, 2015 at 9:32 amno! ive not seen that before, many thanks, i need to log in here more often i think 🙂
John Rofrano
October 28, 2015 at 2:29 am
