Activity › Forums › Apple Final Cut Pro Legacy › Unlinking Audio in a source file.
Posted by Jonathan Drum on August 12, 2010 at 9:31 pmI would like to know if there is a way to unlink the audio in a source file, before putting it in the timeline.
Brian Miller replied 16 years, 1 month ago 3 Members · 4 Replies -
Brian Miller
August 12, 2010 at 9:58 pmhilight the clip, choose modify, clip settings, turn off audio.
Jonathan Drum
August 12, 2010 at 10:07 pmWhen I do that… I get this message: “No items have files that are applicable to this operation”
I’m using quicktime video files (shot on a JVC-HM700U) that use XDCAM EX 108060i and 48 KHz, 16-bit integer audio that is separated L/R in the camera.
Shane Ross
August 12, 2010 at 11:19 pmSee the tabs on the timeline…on the left? Click on the audio tabs to disconnect them from the sequence.
Shane
Read my blog, Little Frog in High Def -
Brian Miller
August 12, 2010 at 11:50 pmif you are still trying to remove the audio from the clip for whatever reason, just make the clip offline fist, then choose modify – clip settings and click off the audio. reconnect and you’re good.
