Activity Forums Adobe Premiere Pro Unlink Keyboard command??
  • Unlink Keyboard command??
    Posted by Pete Peterson on July 1, 2011 at 12:04 am
    Switching from fcp to pp5.5 and so far really enjoying it. I’m setting up my custom keyboard commands but can’t find one for unlinking audio/video. Does this exist?
    Romeen Barryman replied 11 years, 7 months ago 8 Members · 9 Replies
  • 9 Replies
  • Vince Becquiot
    July 1, 2011 at 12:07 am
    Hi Pete,
    If you look in your Keyboard customization settings under Application > Clip, you’ll see unlink.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Pete Peterson
    July 1, 2011 at 12:33 am
    Yeah, I saw that one, but I was looking for one in the sequence panel.
  • Pete Peterson
    July 1, 2011 at 12:38 am
    OK, I just found out that it works in the sequence as well. Thanks for the tip. It’s fun experimenting again.
    https://avpguam.com
  • Ray Ortega
    May 4, 2012 at 8:35 pm
    Hi guys,
    Sorry but I’m using Premiere Pro 5.5. and there is no “unlink” option under Keyboard Shortcuts > application > clip.
    Thoughts?
  • David Jakubovic
    February 14, 2013 at 5:16 am
    Which one was it that you found that works for the sequence unlink, please?
  • Denis Dominguez
    January 28, 2014 at 3:44 pm
    I believe is Clip
  • Marcin Grabos
    January 28, 2014 at 5:10 pm
    Search option in Keyboard shortcuts menu could make things easier.
  • Wes Mcclure
    July 13, 2014 at 1:26 am
    Ctrl+L (which establishes them as linked will toggle to unlink)
  • Romeen Barryman
    January 11, 2015 at 6:54 am
    If you can’t find the Unlink shortcut command, try finding “Link”
    Under Keyboard Shortcuts / Clip / Link
    you can also type “Link” in the search bar,
    then create a shortcut, ^^ like Command+L.
    This can function as unlinking the video and audio, but not relinking them.
    But you can always Cmd+Z, this shortcut is all you really need.
